Quick 'n Easy Web Builder 8.4.0 update
Quick 'n Easy Web Builder 8.4 fixes known problems, adds new features and includes other improvements.
What's new?
- New feature: Added 'Show All' and 'Hide All' commands to Object Manager context menu. This is a quick way to show or hide all objects.
If the selected object is a layer/layout grid then only the elements of that layer will be hidden/shown.
- Improved: Added support for file links to Button and Themeable Button.
- Improved: Optimized the generated HTML of the Responsive Menu for Google's Lighthouse.
- Improved: More efficient memory management for embedded and master pages.
- Fixed: Incorrect column alignment in layout grids and custom overflow with flexbox.
- Fixed: Issue with inset box shadow in Themeable Menu.
- Fixed: Issue with bcrypt in change password.
