Quick 'n Easy Web Builder 9.1.0 update
This is the first major update for Quick 'n Easy Web Builder 9. This version fixes known problems, adds new features and other improvements.
What's new?
- Fixed: Issue with line-break after 'image:svg+xml;' when CSS beautifier is enabled.
- Fixed: Issue with Snipcart API.
- Fixed: Compatibility issue with CMS and PHP8.
- Fixed: FlexContainer at height 75vh shrinks to 20px in workspace.
- Deprecated: The PayPal option 'Allow Customer Note' has been removed because is no longer supported by PayPal.
- Improved: Property Inspector description displays old messsage when switching context.
- Improved: Upgraded to PHP Mailer version 6.5.3. More details: https://github.com/PHPMailer/PHPMailer/ ... angelog.md
- Improved: Mega Menu ARIA support improvements.
- Improved: 'Button only' items in Mega Menus are now also supported in mobile/responsive mode.
- Improved: Flexcontainer direction property now also supports 'column-reverse' and 'row-reverse' in breakpoints.
- Improved: Vertical pagination (center) of the Carousel/SlideShow is now responsive.
- Improved: Added 'width' and height' attributes to navigation images in Carousel and SlideShow (Google Lighthouse improvement).
- Improved: Moved 'vcpopup.css' (Vibracart Pro) between head tags.
- Improved: Responsive behavior of jQuery UI dialog.
- New feature: Added margin properties to DatePicker.
- New feature: Added padding properties to Cards.
- New feature: Added new height options to flex container: 75vh, 50vh, 33vh, 25vh and 10vh
- New feature: Added 'Full Width' and 'Maximum Width' properties to Login Name. This can be useful to limit the size of avatar images in layout grids.
- New feature: Added sandbox support to the PayPal shopping cart.
- New feature: Added the ability to show a delete confirmation prompt ('Delete Confirmation') to the Login Admin to prevent accidently deleting users from the database.
- New feature: Added 'sponsored' and 'ugc' values to rel attribute in links to qualify outbound links to Google. More information: https://developers.google.com/search/do ... inks?hl=en
The update is also available in the Mac App Store.
