Quick 'n Easy Web Builder 13.1 update
This is a major update for Quick 'n Easy Web Builder 13. This version adds many new features and other improvements.
What's new?
- New feature: Added Visual Edit Mode for the Flex Grid.
Flex Grid layouts can now be edited directly on the workspace. Select a Flex Grid and choose Visual Edit Mode from the main menu or context menu (right click) to switch to the new interactive Grid Edit Mode. The workspace displays the grid structure with dashed track lines, track-size labels, empty-cell markers, and color-coded sections so the layout is easy to understand at a glance.
In Visual Edit Mode, you can create new sections by clicking and dragging across empty cells. Existing sections can be moved by dragging them to another position, resized from the bottom-right corner, or removed using the delete button shown on the section. Changes are saved back to the grid template automatically when you leave edit mode.
To help prevent layout mistakes, the editor shows a live preview while dragging or resizing sections. If the target area overlaps another section or falls outside the grid, the preview is highlighted in red and the change is not applied when you release the mouse.
- New feature: Added the ability to add and remove rows / columns to the Flex Grid via the main menu or context menu.
- New feature: Added 'date/time range' type to the Timer object. This adds the ability to set both date and time for the range.
- New feature: Added 'button mode' property to filter of Photo Gallery. This make it possible to display filter button as full width item or as buttons.
- New feature: Added the ability to add product images to the shopping cart. Via the 'Images' button you can assign images to the product ID.
- New feature: Added support for Up and Down directions to the Conveyor Belt.
- New feature: Added a 'Pause on hover' option to the Conveyor Belt. This controls whether scrolling pauses when the mouse pointer is over the Conveyer Belt.
- New feature: Added a loop property for Background Video mode, allowing you to choose whether the video repeats continuously or plays once.
- Improved: Server sided validation (PHP) of File Input and Select.
- Improved: Easy Breakpoints now overrides the font size of all items in Cards.
- Improved: Backdrop-filter (Glass-morphism) is now applied to Heading container instead of the text only.
- Improved: Upgraded PHP Mailer to version 7.1.1. More details: https://github.com/PHPMailer/PHPMailer/ ... angelog.md
- Improved: Added support for pasting YouTube and Vimeo URLs directly into the workspace. When you paste a URL into an empty area, a new YouTube or Vimeo object is created automatically. You can also paste a URL onto an existing video object to replace its video.
- Improved: Added 'Role' column to the Login Administrator user overview.
- Improved: The Photo Gallery thumbnail view has been redesigned to produce cleaner, more modern layout code (display:grid). This also improves the behavior of the filter option.
- Improved: Image Converter now remembers output path.
- Improved: Text with margins in Easy Breakpoints adapt the container width.
- Improved: When the height of the Flex Grid is set to 'auto' it now behaves more like the Layout Grids, the flexible grid items (eg. 1fr) will automatically shrink and grow in the workspace based on the content.
- Improved: Flex Grid now handles object cleanup more reliably. When a grid section is removed, any objects inside it are also removed automatically, preventing unused objects from being left behind on the page.
- Improved: Flex Grid alignment via main or context menu now also updates align content property.
- Improved: Flex Container layouts now behave more consistently with modern browsers when using column direction together with wrapping: flex-direction = column / flex-wrap = wrap.
- Improved: Stripe integration has been upgraded to the newest API.
- Improved: Increased the MySQL IP address field length to 50 characters to support IPv6 addresses.
- Improved: Added the ability to set the value of text objects via Events -> SetValue.
- Improved: Conditions -> Set Choices, no longer groups separate 'equal to' conditions.
- Improved: Conditions -> It's now also possible to use the name of a radio button group as reference, in addition to the ID of the first radio button of a group.
- Improved: Several improvements in Image Accordion and Thumbnail Gallery.
- Fixed: PayPal JavaScript SDK requires order capture.
All users thanks for your feedback!
