How do I create a transparent inline frame?
Here's how you can create an inline frame with a transparent background.
This will allow you to create scrollable text with the background of your main page showing through.
Part A:
1. Create a page with the text your want to scroll.
2. Open Page HTML and enter this code in the Between Head Tag field:
<style type="text/css">
body
   background-color:transparent
</style>
Part B:
3. Create a page with an IFRAME (Inline Frame)
4. Set the URL to the page above.
5. Open the Object HTML for this inline frame.
6. Enter this code in the Inside Tag field:
allowtransparency
7. Preview or publish this page to see the effect.
