Why a totally new product?
PLEASE READ THESE MESSAGES IF YOU HAVE PROBLEMS WITH YOUR ORDER OR ACTIVATING THE SOFTWARE
One of the most frequently asked questions we get is 'Is there also a Mac version of this software?' Unfortunately WYSIWYG Web Builder cannot run on the Mac and its source code cannot be ported to the Mac because its uses many Windows technologies that work very differently on the Mac. So we decided to create a complete new product designed from scratch specially designed for the Mac, but with the possibility to port it to Windows and Linux.
Although we've integrated the best features of WYSIWYG Web Builder into Quick 'n Easy Web Builder, it is not the same software! It does not use the same project structure and projects are not interchangeable.
The core of the software is very different because Quick ‘n Easy Web Builder has to be compatible with multiple operating systems, also many of the used technologies in WYSIWYG Web Builder are not available on other platforms (yet). However Quick ‘n Easy Web Builder is still very advanced and it certainly will be one of the best web design tools available for the
Mac/Linux!
Quick 'n Easy Web Builder also needs a separate license, because without its own funding we cannot continue the development and support of this product.
So if you like the application and wish to support this product then please buy a license and help us make Quick 'n Easy Web Builder (even) better.
See also:
http://www.quickandeasywebbuilder.com/f ... 30&t=40257
