Quick 'n Easy Web Builder 5.1.0 update
What's new in 5.1.0?
- Fixed: Background overlay in floating layer needs z-index.
- Fixed: Open Graph Meta Tag og:url is missing.
- Fixed: height should not be included when 'Login Name' is part of a Layout Grid.
- Improved: Now includes jquery-3.2.1
- New feature: Added new alignment mode to Layer Menu: 'Container width'.
- New feature: Added 'Include locked objects in lasso selection' option to Guide Settings. This specifies whether to include locked objects should be included in lasso selection.
- New feature: Added 'Rotate' option to Photo Gallery, Photo Collage and SlideShow properties. This makes it possible to quickly rotate an image without leaving the application.
- New feature: Added 'Place Holder' property to jQuery Auto Complete.
- New feature: The Photo Collage properties now displays the number of images used by each layout.
- New feature: When using 'Convert to form' for Login forms which are inside a layout grid, the child elements will be converted to floating elements. The layout grid will be used as the form container.
- New feature: Added 'Open master page' option to the context menu of Master Page object to quickly open the embedded page.
You can download version 5.1.0 here:
The update will also be available in the Mac App Store (this may take a few hours).
